![]() | Home > Faults & Fixes > Fuel gauge reading empty when full... |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784
This any good to you?
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
Hi, as OaC has highlighted ^
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
sorted |
Don’t suppose you remeber the cost? Pm me if you don’t want to post publicly, just want to know what I can do with this guy coming to look at my car regards purchase price etc. |
Is this a LRJ TSB that refers to your problem? Don't know if you would have any luck bearing in mind the age of the car;
Can only but try, have sent Col a pm hoping it can help. |
| harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395
I had this problem with my Facelift 2009 Sport, three years ago.After a bit of research. I was told that Landrover were aware of this problem( it was the wiring on sender unit. It entailed dropping tank and changing wiring connections on sender unit. Main agents denied any knowledge of this. But after contact with customer services, they did the job without cost. itisme |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Have replied to pm, but just remember there is a pdf copy in my gallery which can be downloaded File No. 37 however the bulletin is for the facelift variant of the RRS1. Cheers Col |
Awesome thanks Col. |
Where can I get customers services contact details? |
| fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180
Had the same fault about 6 months ago (2011 RRS). Got the same link from Col and forwarded it to our local Indie. Tank was dropped & sender unit connectors changed. Worked correctly since. Think I was charged about £80. |
Fingers crossed but All working now, i removed the drivers wheel and dried out the wiring connectors i found behind the inner wheel arch using a heat gun, whether by pure chance or luck after this its been fine for the last 2 days, I did put the pressure washer right up into the archers when i gave it a clean on friday and it was the first time this happened directly after i left the jet wash. |
| All times are GMT |
