Home > Faults & Fixes > Headlight bulb gone purple
Wayneclarke
Turned the car on this morning and thought wow my lights look a bit pink, got out and the drivers side is purple !!!! Does anyone know what type of bulb I need to replace and I’m guessing just like a normal bulb I need to change both xenons.
Post #551295 Wed Mar 14 2018 7:02am
Smarttech
All depends on the age of the car ! Early RRS1 had D2S bulb and later facelift cars like mine have D3S bulbs so might help if you state age and L320 or L494 ! 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #551296 Wed Mar 14 2018 8:05am
Wayneclarke
I’ve got an 06 l320
Post #551297 Wed Mar 14 2018 8:31am
Smarttech
Should be a D2s xenon bulb then. Quit often an idea to change both as could end up with 2 different colours if not the same bulb spec 2019 4.4 SDV8 Autobiography Velocity blue.
Post #551300 Wed Mar 14 2018 8:54am
Wayneclarke
Is there any certain make I should get ? I’ve never had these lights before so I’m a total newbie sorry
Post #551301 Wed Mar 14 2018 9:04am
Wayneclarke
Also what power are they ie. 4300k - 6000k !!!
Post #551304 Wed Mar 14 2018 9:32am
The type of bulb (D2S etc, H7 etc) is moulded in to the top of the headlight plastic. You can read it when you open the bonnet. Easy to check and avoid buying the wrong bulbs. 2012 SDV6 - it's missing a couple of cylinders
Post #551328 Wed Mar 14 2018 11:25am
Wayneclarke
That’s brilliant thank you for the info I will check soon as I’m out of work
Post #551329 Wed Mar 14 2018 11:40am
shepp
[quote="Wayneclarke"]Also what power are they ie. 4300k - 6000k !!![/quote
That is not the power, it is the colour, lower is yellowish, higher is blueish] MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #551382 Wed Mar 14 2018 8:10pm
Wayneclarke
Yeah sorry that’s what I meant, I took the light out earlier and the bulb is an osram xenarc 4300k so I’m thinking of replacing with the new osram night breaker
Post #551384 Wed Mar 14 2018 8:13pm
shepp
The only issue with the nightbreaker, it makes your other lights (sides and corner) look very yellow. The nightbreakers are good but have a blue tinge. I fitted them to my previous RRS when one of my lights went pink. MY12 RRS HSE
Gone 90
Gone s2000
Post #551386 Wed Mar 14 2018 8:22pm
Wayneclarke
I’ve ordered them now so see how they go at worse I can always buy original again
Post #551390 Wed Mar 14 2018 8:50pm
