![]() | Home > Wheels & Tyres > Mixing 40 profile and 45 profile? |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1550 ![]() ![]() ![]() |
Can I run 275 45 R20's on the rear and 275 40 R20 on the front? I guess not as it will screw up something.
Cheers Buckster. I thought as much but worth asking |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
You`d be increasing the diameter of only 2 wheels then.
jzive Member Since: 23 Feb 2014 Location: Essex Posts: 80 ![]() ![]() |
Agreed, would advise against mixing profiles. |
![]() 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
http://www.rrsport.co.uk/forum/topic35871.html
Put a decent pair of part worn tyres on to match the others Robin
Now there’s a thought. |
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 ![]() ![]() |
Yes, you can. A lot of BMW's have wider wheels on the back, and therefore have a different profile. Eg, you would have say a 305/45 on the rear. You would need to work out exactly which on a calculator. The 40 just means 40% of the width. 2012 RRS SDV6
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5094 ![]() ![]() ![]() |
Agreed, no-one suggested putting a 245 on a 9.5j rim from what I can see. I just said it can be done. 2012 RRS SDV6
The 40/45 is the profile (height), not the width though. The staggered setup on the likes of M3`s won`t affect the overall circumference just because the rears are wider. Steve. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The BMW are designed with this odd tyre arrangement from the outset, however. The RRS is designed to run the same all round. Just because you can, doesn't mean you should. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
