![]() | Home > General > lean when cornering and suspension lying down |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
I had the same fault on an early Range Rover sport - it was diagnosed as the suspension air pump iirc . Car was under manufacturers warranty but it was a 2 grand part as I recall. Same symptoms as you mentioned. But this was 13 years ago so I might not have the exact details correct.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Do you mean this light? ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5045 ![]() ![]() ![]() |
first thing to do is change the seals in the front air block . (and clean it out)
