| RRSPORT.CO.UK | ||
|  | Home > Technical > 2008 Range Rover Sport Diagnostic results |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | Ignore the u codes for now you more than likely have a short to earth in the sensors try and unplug the front sensors first the plug is behind the front drivers headlight and then try it if the fault is still there try unplugging the rear sensors which is in the rear of the car on the passenger side i think  | ||
|  Sun Mar 04 2018 5:02pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | |||
|  Sun Mar 04 2018 5:04pm |
| JimMcneil Member Since: 25 Aug 2012 Location: Scotland Posts: 13    | Thanks very much, what’s your thoughts on the cruise control issue?
|  Sun Mar 04 2018 5:14pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | Make sure your front acc is clean and clear sounds like it has something blocking what it can see  | ||
|  Sun Mar 04 2018 5:38pm |
| JimMcneil Member Since: 25 Aug 2012 Location: Scotland Posts: 13    | Hi the ACC is fully clear. Is it worth taking off the front bumper to check for broken wires to the ACC unit? | ||
|  Sun Mar 04 2018 6:28pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | i assume you have just got the car yes you can take the bumper off and make sure everything is connected up properly and no breaks in the wire but it will be worth spraying the screws at the bottom of the bumper as they tend to round off   | ||
|  Sun Mar 04 2018 6:46pm |
| JimMcneil Member Since: 25 Aug 2012 Location: Scotland Posts: 13    | Many thanks for the advice will keep this post updated once I get the bumper off the car...and when I check the parking sensors.
|  Sun Mar 04 2018 8:16pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | I am adding to a situation , I have with the same fault . Ok have used GAP to identity that the rear sensors are all detected and the front otherwise.
|  Mon Apr 17 2023 9:24pm |
| Posting Rules
