| RRSPORT.CO.UK | ||
|  | Home > General (L494) > Side vents/bonnet vents |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533    | Steve. | ||
|  Wed Feb 28 2018 7:59pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Mine the L494 Steve,,or are they same fit.?
|  Wed Feb 28 2018 8:04pm |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533    | 2010 on...
|  Wed Feb 28 2018 11:04pm |
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378      | |||
|  Thu Mar 01 2018 6:32am |
| V8tdi Member Since: 30 Apr 2017 Location: Powys Posts: 70      |
 Hi I change both on my l494 You need a trim tool essential to do the swap I removed the lining on the inside of the bonnet just simple clips let’s you get your hand under the vent Simply click the tabs and it pops of The wing is also easy with the trim tool but be very careful it has a sticky pad at the end you need to lift this first While doing that be very gentle there are two tabs that easily break Then slide forward and it comes of Good luck Ken | ||
|  Thu Mar 01 2018 8:31am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Tks Ken,,yes I see the rear of the vents are held on with 3m tape so ill get something like fishing wire to separate that 1st.
|  Thu Mar 01 2018 8:49am |
| HossBog Member Since: 22 Aug 2017 Location: Cotswolds Posts: 54    | I used a bike tyre lever on the side vents - start at the back and very gently pull the strakes out with your hand and then use the bike lever where you can feel the tabs are. Then just gently wiggle them out.
|  Fri Mar 02 2018 7:17am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | That what I was thinking HossBog,,its a bit cold for snapping the plastic tabs,,ill wait till it warms up slightly & probably heat them up with my blower I use for drying the car.
|  Fri Mar 02 2018 7:42am |
| HossBog Member Since: 22 Aug 2017 Location: Cotswolds Posts: 54    | I also found out yesterday that the silver mesh in the bonnet vents can be detached from the black surround. It just clips in. You can pull it out by carefully popping it from the longest side. So you can spray the mesh without having to mask anything. Prob best to do it with the vents off the car tho! | ||
|  Sun Mar 04 2018 12:46pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Tks again HossBog,,I didn’t know the silver bit was only clipped on,,easy job for the lad who’s going to paint then,,I just need to get a colour match paint now.
|  Sun Mar 04 2018 1:06pm |
| Posting Rules
