![]() | Home > Technical > 2008 Range Rover Sport Death Wobble |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Easiest way is if you know someone else with same car & swap wheels over.
| PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402
I had a wobble at speed turned out to be the brakes binding, got them replaced on under warranty from the garage i purchased it from. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Agree that sounds like binding front brake. I had the same on my old Jeep Cherokee. Completely out of the blue experienced the shaking quite violently. Easy to tell if you stop and feel the wheels the offending side will be hot and/or terrible smell of overheated brake pads.
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420
Yep, me too. Shortly after buying my car after it had been sat on a forecourt for a good few weeks. The chronic shaking turned out to be a binding o/s rear brake calliper and a binding n/s front. Only discovered after an episode of this shaking, pulled over and felt the very hot wheels. A new rear calliper and new pistons/seals in the Brembo front... problem sorted. |
| Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31
I don’t have access to another set of 19” Wheels/Tires. Interesting info about the brake calipers binding. I’ll keep my temp gun in the car and check the brake temps next time it happens.
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
If you have replaced/rebuilt the front suspension, then I hope you have had a "proper* Wheel Alignment. Excessive Toe-out or Toe-in can cause a serious shake. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559
Have you swapped tyres front to back? Some tyres get wear that can cause issues ( my Uniroyals for one) and whilst the shaking issue is not the same symptoms as mine, its an easy and cheap check to just eliminate this as a possible problem. They would still balance OK but on the road would throw up issues when under load.
UPDATE:
Glad you got it sorted and relatively easily. It’s a shame that some “automotive specialists “ aren’t.
