Home > Technical > Re seal or replace air compressor pump
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
What’s the best way forward, re seal the pump or buy a new one ? I’ve got a 2010my and I’m told I have a hitachi pump, should I replace with the newer type one ? And will I get a software issue? Also can I put the car into off-road mode for more access for repair and will I need to remove the rear wheel? Thanks 👍🏻
Post #549436 Thu Feb 22 2018 10:59am
DrRob
I think consensus is replace the whole thing.... * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #549446 Thu Feb 22 2018 12:00pm
Socast
If you fit the newer AMK type compressor you will need to update the software.
If you intend to change the compressor yourself you'll be able to get to it by raising the vehicle to off-road height (if you can) and putting the nearside wheels on the curb, that will give you all the height you need. I seem to remember something about a few of the bolts being prone to snapping in a bracket.. but other than being careful not to damage the airline it's a fairly straight forward job. It can be a pain trying to get the enclosure back on in such a way that the whole thing doesn't vibrate with the pump like a drum Thumbs Up
Post #549502 Fri Feb 23 2018 11:23am
paul2415
Put into off road mode and removed the relay, removed the compressor quiet easily apart from top bolt, I am going to do a re seal as all in very good condition, local 4x4 dealer wanted £850 to replace, plus £100 if software required, whole job should only come to £75, fingers crossed, will take care with the case, thanks 👍🏻
Post #549509 Fri Feb 23 2018 12:45pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
reseal.
easy to do.
no reason to throw out a perfectly serviceable unit
Post #550300 Fri Mar 02 2018 11:31pm
paul2415
Have re sealed the compressor, was not too bad, re fitted, had no messages on dash, seems to work better than before, so all good so far 👍🏻
Post #550310 Sat Mar 03 2018 8:27am
Oldandconfused
You say "re-seal", do you know what the problem is?. The plastic end cap (where the air lines come out) have a tendency to crack between the air lines and can be tested by spraying soapy water on it and looking for bubbles. I had this on my D3, bought a cap of ebay for less than £30 and fitted it myself on the drive. No need to take the compressor off, just remove the lower cover.
Of course it may not be that and the compressor may be shot anyway, but worth a look.
Post #550318 Sat Mar 03 2018 9:47am
paul2415
Pre repair, had warning light on dash to say that normal height only, was slow to lift to standard height, kept saying raising on dash, re moved whole unit, placed new piston seals etc, new cap on air dryer and new internals etc, now no messages on driving, quicker to lift to normal height, all good so far, had no leaks pre repair that I’m aware of, apparently a common problem with these compressors👍🏻
Post #550320 Sat Mar 03 2018 9:54am
Oldandconfused
My bad, didn't see your pervious post Embarassed
Glad you got it sorted Thumbs Up
Post #550334 Sat Mar 03 2018 12:36pm
