![]() | Home > General (L494) > SVR Light Load Tyre Pressures |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
I usually run my fronts at 34 & rears at 37-38.
| Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245
I would run around 40psi all round. It is a heavy car and they will wear nice and square then. |
| SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827
the book says 34 front, rear 37. SVR 2018 in Santorini Black. |
| GJW1 Member Since: 19 May 2015 Location: UK Posts: 447
Ive gone inbetween so 36 front and 37 rear.
Whats the problem GJW ? SVR 2018 in Santorini Black. |
Car pulls to the left to make it go straight you need to hold the steering wheel at about 12.30 but if you let the wheel auto centre then it pulls left.
Without having seen it, of course, it sounds like the steering track rods need shortening on one side and lengthening on the other, because the current set-up is not placing the power assisted steering in the neutral position when the wheels are straight ahead.
| Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254
indeed. to be more precise , it seems you need some proper toe settings RRS 3.0 SDV6 HSE Lux
Hunter Alignment...
Thanks for that info guys I can make my own enquiries and get it sorted from one of those listed on the website link and fingers crossed they are as knowledgable as you Black Bess and Hog. |
| ikeysolomon Member Since: 02 Jul 2007 Location: High Wycombe Posts: 60
Any more input, can't seem to find the right balance. |
I’ve not had time to get the wheel alignment sorted but I have a few spare days next week so will have to make an effort to get it sorted then. |
| andymc Member Since: 04 Jan 2017 Location: london Posts: 127
for the last year I've only ever used the recommended pressures from the info on the door pillar. No issues here. SVR with a few bits from Urban and Glohh |
4 wheel alignment done today it was a bit out but fixing it has made a big difference.
| All times are GMT |
