![]() | Home > Technical > Random Activation of Traction Control |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
If the traction is activating It is because the system has measured a wheel speed rotation that is is above or below the limit set out in the software . Mabye the bigger tyres are having an effect on the system. Also the bigger the tyres the more important tyre pressure would be as it effects the overall size of the tyre.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1199 ![]() ![]() ![]() |
probably one of the ABS sensors has a loose connection, is dirty, or is fubar.
ABS sensors are at the back of hub you steering angle sensor may need resetting as well |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Thanks for all the pointers Guys, I'll get the garage to run a check on those items.
Yes it would tell you if either were faulty |
Geoffsnook, finally got round to having a look at his with the IDD Tool. However, I can't fathom out how to see if there's a fault with either the ABS sensors or the steering angle sensor?
If they do have a fault then either the abs or steering wheel sensor would throw a code and bring on a dash light if they are not bringing lights on then it thinks it is doing what it is supposed to do i assume you had no issues with the previous wheels and the diameter setting of the road wheels would it be worth putting them back on and resetting the size with the IDD tool |
Thanks Geoffsnook |
