![]() | Home > General > parking senors / fb heater.fogs fixed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
FOGS AND Parking sensors are common issues.
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 ![]() ![]() ![]() |
thanks for the reply Andy
yipeeee |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
FBH only kicks in when o/side temp is very cold as its there to help raise the water temp to get the car warmer quicker |
needs to be around 4 to 5 °C (or less) for it to kick in once the engine is started |
Minimum temperature to start the FBH stated to be different depending on where you look in LR documentation but is definitely in the range of 4-6 degrees C and in my case seems to coincide with the snowflake symbol appearing in the dash display. Also remember it won't start if fuel level is below 1/4 tank.
hey paddi
buy one or two sensors off ebay. (£10 each)
ill do that cheers Andy |
you do need luck on your side, as the fronts can interfere with the rears
iv ordered a new senors so fingers crossed mate.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
This might help with the parking sensors
cheers eaters..
well iv tried the new sensor in the rear bumper but no luck |
