![]() | Home > General > TDV6 crank failure prevention? |
Yes buy a Supercharged, otherwise it's probably pot-luck. |
Pray!!! |
micknolan Member Since: 19 Apr 2017 Location: West Midlands Posts: 45 ![]() ![]() ![]() |
Taken from another forum may use.
The problem I see here is, the ones that snap are not even getting to that mileage one appears to be as low as 16k.
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
It’s a tricky one isn’t it? Most V6 diesels won’t fail, many reaching very high mileage without a problem but there are enough that do suffer the fault to make it a significant worry for all owners. In many ways, it would be easier to determine a definitive cure if all LR V6 diesels died as a result of a failed crankshaft but as it is, most go through their life without issue.
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
L r there preventive measure
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1206 ![]() ![]() ![]() |
there is no way to predict this failure, nor a way to prevent it.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
So it is a matter of when not if..? Do we know what causes the failure? Sen a couple of posts suggesting oil starvation..? |
+ Join the Magic Circle ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 249 ![]() ![]() ![]() |
Before my suggestion I will point out I am running petrol supercharged..
Andrew.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
That seems to be discussing 2.7l main bearings, I thought the failure issue was with the conrod bearings? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
I personally believe that uncompleted DPF regens, wrong oil (the right one is a 5W30 c1 or c2) and/or oil dilution are important factors for crank seizures.
the ZA and OZ-spec SDV6 did not have the DPF, so your argument is invalid for those markets. It may still be a factor for EU-spec though |
