![]() | Home > Wheels & Tyres > Fitting 275/45/20 tyres |
dobbo9 Member Since: 04 Dec 2011 Location: West Yorkshire Posts: 108 ![]() |
I'd be interested in this too...The 275/40/20 feels a tad harsh to me. |
275/45/20 is the way to go no mods required and no speedo issues. I’ve been running that size for years. I changed my spare for a match wheel/tyre as well. 2008 G4 RRSport TDV8 current
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
I have just fitted the 45 profile speedo is now only 1mph out at 70 when compared to the GPS. No issues with access height but not deflated the corners to check if any issues but you wouldn’t be driving it that low anyway.
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 ![]() ![]() ![]() |
Ok thanks guys, looking to put a set of hankook ventus st m&s, had these on my last rrs running 275/40/20 tyres, any different in Corning at speed? Thanks |
My spare is a 175/80/ r19, so would need replacing? As not much room under the rear to fit a larger diameter spacesaver wheel, recon 15mm before it would foul the box section of the bumper😳 |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
We have the Hankook Ventus 275/45/20 fitted. Great tyre & Much improved ride. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5078 ![]() ![]() ![]() |
There is sufficient room underneath to fit a full size spare with a 275/45 x 20 tyre without to much trouble. Cheers Col |
RESSE Member Since: 30 Dec 2017 Location: Shropshire Posts: 15 ![]() ![]() |
We need to replace our 275/40 20 tyres shortly - if I have read correctly changing to a 45 profile doesn't cause any issues? |
I ran 275/45 x 20" for several years, now run 275/45 x 21" and have had absolutely no issues what so ever, the difference in speedo reading is also negligible in fact if anything it is more accurate.
Wow, what a transformation!
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Sounds like it’s worth doing?
I informed my insurance company (Admiral) who made a note on the policy but other than that nothing else needed to be done. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1196 ![]() ![]() ![]() |
chaps, are there any other higher profiles that one can fit to the 20" wheels? --
![]() ![]() 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
