Home > General > Thinkware F770 2CH Dash Cam.
PEACHY
Col - came out yesterday afternoon to the dreaded ` SD CARD EJECTED ` voice message on the dash cam Big Cry The card had recorded for 7.5 hrs without issue - how long did you keep the cards in for ?
Tried to reformat the card but no good - it worked but only for 24 hrs Big Cry
Back to the drawing board Rolling Eyes 16MY Estoril Blue SVR.............
Post #548908 Sat Feb 17 2018 11:06am
Had them in most of the day, but have been playing about with them both on and off during the day so probably not a good test yet, have just completely reformatted one will put in in the car and see what happens over the next couple of day's. It should spend the next few hours recording the inside of the garage door Rolling with laughter as it's nearly midnight here. Will let you know what happens.
Post #548909 Sat Feb 17 2018 11:18am
PEACHY
Another Censored Censored - so after a week the dashcam turns itself off after approx 30 secs from start up Big Cry I've had the ctek on it and fully charged the battery - the FBH works off the plipper & timer which suggests it's not the battery BUT the auto stop start is highlighted on the dash panel which does suggest low battery Big Cry I've put the 12v lead in the cam & reset as per the manual & plugged it back into the hardwired cable but no change Rolling Eyes
Any ideas apart from throw it in the Censored bin Rolling with laughter Rolling with laughter
Thanks in advance Thumbs Up 16MY Estoril Blue SVR.............
Post #549473 Thu Feb 22 2018 10:21pm
Were you doing anything with the camera when it happened or was it just switched on as normal. Could try updating the Firmware if you haven't already as they have recently released an update, only a suggestion though.
Just to Censored you off a little bit more Buddy, have used the 128GB SanDisk for nearly a week now and had no problems at all, used the app and camera to format card a couple of time and swap the settings/modes around a few time and still working fine.
Post #549491 Fri Feb 23 2018 10:27am
@Peachy
is this similar?
http://www.rrsport.co.uk/forum/topic29875.html?highlight=blackvue
Post #549512 Fri Feb 23 2018 2:14pm
PEACHY
Col - npinks - thanks both for your input & feedback Thumbs Up
The fitter had wired the cam to the small aux battery ( don`t ask me why ) - he knew straight away what was wrong & rectified the issue Sunday morning. I had already downloaded the latest firmware so now it works as it should - parking mode only records on motion detection meaning it recorded from approx 9pm last night. I was also greeted by a message telling me how many recordings it had made ( 10 in this instance ). I will now try again to install the larger sd card but I`m a little happier Wink
I now have the issue of the start /stop not being available & a full days charge on the ctek hasn't rectified the issue - will this recharge through normal use or do I need to do something different ?
Thanks all Thumbs Up 16MY Estoril Blue SVR.............
Post #549744 Mon Feb 26 2018 8:09am
Tyrefitter
Morning,,you guys mention a update for the 770,,where do I get this so I can do it on both my cams & wheres the best place to get the 128gb card from.?
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #549748 Mon Feb 26 2018 8:57am
Andy, you can download update from here.
http://www.thinkware.com/Support/Download
I got my 128GB cards from Amazon.
https://www.amazon.co.uk/SanDisk-microSDXC...dpSrc=srch
Post #549753 Mon Feb 26 2018 9:59am
Tyrefitter
Thanks Col.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #549756 Mon Feb 26 2018 10:11am
