![]() | Home > Technical > Turbo Flutter / Surge - Is this normal vid attached SDV6 |
Mine does it so does my brothers SDV6 Disco 4. I would say it’s normal and to do with the change over of the turbos. Even more noticeable in low range under heavy load when off-road 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426 ![]() ![]() |
Never heard this on mine ! Will try driving it with the stereo off today and see if I get the same noises from the turbo. Do SDV6 engines not have a recirculating valve ? as you shouldn't get turbo stall if they have and the back pressure is not good for the turbo. 2019 4.4 SDV8 Autobiography Velocity blue.
RRS2012 Member Since: 02 Feb 2018 Location: Sheffield Posts: 13 ![]() ![]() ![]() |
Thanks chaps. Off to th steelers shortly have asked them to demonstrate the noise in another one for my price of mind.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
Lag is quite common. Sometimes goes after software updates or get a remap from Alive Tuning |
The vey accomdationdating steeler demonstrated this on another one (newer 15 plate) so is normal as suggested above now confirmed. I guess the lag is normal, an air leak, or a software issue. They’ve got it until next week for a couple of other promises the sales guy made but weren’t completed so will just make sure the software it’s up to date etc.
Have been listening out for this today and never heard it once !
