Home > Maintenance & Modifications > Drls
Morgi27
Drls
Hi guys
I was thinking of adding some drls to my range rover sport 2.7td 2005 not the halo type that go into the light unit but other type that fit to bumper
Can anyone suggest any particular kit for this and if you've fitted themselves how do they look and is installation easy ? Cheers
Post #547035 Mon Jan 29 2018 12:54pm
Morgi27
I've found this on ebay think they been suggested used before on here eBay Item No. 142018758904 ebay number
Design anyone have them fitted and if so any instructions and pics please
Cheers guys
Post #547036 Mon Jan 29 2018 1:04pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Those DRL units will use a voltage sensing relay to turn on the lamps, so the only connections will be to the +ve and -ve terminals of the battery.
Issues:
1) The lamps will turn on when a charger is connected to the battery.
2) The brackets are likely to rust.
3) The seal between the lens and the housing are likely to leak water. Even genuine Philips units have this problem, I have had 3 Philips units which have done this.
Post #547130 Tue Jan 30 2018 4:02pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Easy fix, wire them to an ignition live terminal in the under bonnet fuse box
Post #547151 Tue Jan 30 2018 8:21pm
jason-nike
Its easier than you think to fit halos, opening headlights isn't too bad.
Did both of mine in under 2 hours start to finish
Post #547163 Tue Jan 30 2018 9:27pm
