Home > Faults & Fixes > 2006. Radio and sat nav screen stopped working
Brad83091
Ireland 2006 Range Rover Sport TDV6 HSE Luxury Java Black
In short. The jeep was parked up for the last for 10 days( for no fault of its own). Had to go on a trip yesterday 200km round trip. Went out last night to start up the jeep and noticed both the radio and sat nav screen were both dark... I did a quick search on the forum. I checked the 3 fuses that relate to the radio All were ok.
I hadn't much time to spend investigating. So I set off on my trip with no radio or nav.
I'm just in the door now do I'm seeking sum advice.
Post #546787 Fri Jan 26 2018 12:11am
well i would start buy checking the headunit has power.
I assume nothing is displayed on the green headunit display? No clock ?
Post #546811 Fri Jan 26 2018 12:22pm
Brad83091
No errors on screen. And no clock also
Post #546856 Fri Jan 26 2018 10:03pm
Brad83091
Update.
All fuses are ok no problem there. Still both nav and radio are dead.
Where to look next
Post #547627 Sun Feb 04 2018 4:58pm
Brad83091
Just did a hard reset and noticed the led lights going into the cd changer flashing?????
Post #547632 Sun Feb 04 2018 5:57pm
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
how old is the car battery ? it might need changing.
In a bmw m3 I owned, I would regularly have an issue where the Nav/TV would not turn on. I would basically have to "reboot" the system, and did this buy pulling the +/- on the car battery for about 60secs and reconnect. They would come back working after that.
Post #547745 Mon Feb 05 2018 4:37pm
Brad83091
2006 vehicle
Battery is 3 years (Bosch).
Did 2 hard resets (different evenings). No improvement
Time to book in with my local independent.
I'll be sickened if it turns out to be some thing simple
Post #547994 Wed Feb 07 2018 10:10pm
jason-nike
Had a similar issue on my old RRS 2005.
Headunit was dead, no radio, no sat nav, no sound.
Ended up having to replace optical loop, once done all was fine
Post #548000 Wed Feb 07 2018 11:39pm
