![]() | Home > Technical > EPB |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Mine does. RRS MY17 SDV6 AB
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Configurable option. |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
Thanks guys. Configurable? I couldnt see anything? |
I'm on my 6th sport 4xL320's & 2xL494 & none of them have applied the park brake when putting car into park.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
My L320 didn't automatically apply it when I got it, but I set it to apply with my iiDTool. Now it applies in all gears except when in Park.
Thanks all. So it seems a little inconsistent!
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Mine doesn't, and I don't see anything in the set up menus to make it do so. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
Mine doesn't. Never use it anyway. Only time its on is when I pick the car up from a service. Only notice it then as there is a hesitation on moving off when it automatically disengages |
Yeah, its odd, why some would have it enabled and some wont. Reason i ask is, is that is was in for some warranty work and i mentioned it, so they replaced the EPB module and i assumed it was fixed, but its not fixed it and i dont know whether i should go back with it. We have only had it a few months so keen to point out these 'faults' now. But i am now unsure! 2015 RRS AB SDV6, Fuji White, Ivory
I just can't figure why anyone wouldn't use the handbrake, why risk your gearbox? Would you leave a manual only in first gear (yes we've probably all done this when the handbrake fails)?
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Surely it`s fine to leave it off if the car is parked on the flat |
Is it not simply driver preference, if you want it to apply automatically when stopping the car you have the feature enabled in the CCF files, if you wish to apply it manually yourself you have it deactivated. In either case it will automatically release when you engage drive and pull away, although personally I prefer to release it manually prior to pulling away.
I always engage the hand brake except when leaving for long periods on the flat. Thats why i liked the idea of it auto engaging when in park.
Col. Is that an option on L494 to enable it perhaps? But why when i mentioned it to the dealer did they order a new EPB module and then return it without enabling it. The EPB was working fine manually when it went in. Very odd. 2015 RRS AB SDV6, Fuji White, Ivory 2012 RRS HSE SDV6, Sumatra Black and Ivory Audi A5, 3.0 TDI, Gone Audi TT, 3.2 V6, Gone BMW 5 series tourer, Gone |
