![]() | Home > General > Parking sensors not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Wonder if it's had a replacement front bumper ?
Pauly14666 Member Since: 14 Jan 2018 Location: Dublin Posts: 20 ![]() ![]() ![]() |
When I scanned it it says that the four sensors are faulty I can't see it been the four sensors could it be the module? |
Is it complaining about 4 missing ones at the front ?
There is none fitted to the front |
English HSE's have parking sensors at the front.
This car is in Ireland |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 ![]() ![]() ![]() |
I think Andy meant Is it possible that the car originally had parking sensors at the front but the bumper has been replaced for one without parking sensors as this is exactly what was wrong with my car and because the 4 front sensors were missing the rear pdc didn’t work either, if your diagnostics let’s you view live data maybe try and see what each sensor reads but if it won’t communicate with the diagnostic then it is possible the module or power supply/fuse could be at fault. Clickadeeclick |
When I scanned it it said that the four rear sensors are gone and noting about the front so if that is the case that there was front fitted I'm sure the computer would have a fault for the front aswell i had a bmw before the had this problem I changed the module and it was sorted any ideas were to get a module? |
