![]() | Home > Technical > Multi point entry won’t enable? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
you have to hold both buttons for around 5 seconds until the locks make another noise |
| Tas Member Since: 20 Dec 2017 Location: Sussex Posts: 3
The locks make a noise but still behave the same way, could something be broken? If I press the remote twice it all unlocks. |
I have tried the spare key and that one works! There must be some difference between the two keys..
| phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198
Have a look in the menus on the dash panel, I seem to recall there
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
Maybe only the one key has been programmed. Steve. |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
If its like my 2008 then one push of the open button only unlocks the drivers door. You nee to push the same button a second time to unlock the other doors. From the handbook: 3. Unlock button: Press once to disarm the alarm and unlock the driver’s door and to activate the Lazy entry feature. See Lazy entry, 57. Press again to unlock the remaining doors. See Single-point entry, 42. Single-point entry This is a personal security feature, which enables only the driver’s door to be unlocked, leaving the other doors in a locked state. Single-point entry can be disabled on individual remote control keys by pressing and holding the lock and unlock buttons together for three seconds. Repeating the procedure will re-enable the feature. Each time single-point entry is turned on or off, the vehicle will lock then unlock into the selected mode (all doors unlocked or just the driver’s door unlocked). Does this help? Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
I think he knew that.
| All times are GMT |
