![]() | Home > Duckworth Parts > Under bonnet soft rubber buffers |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Lindab - nice to see my pic came in use |
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934
Peachy, Thanks for the use of your pic. It all came about by chance. I was asking about fitting a Ctek connector under the bonnet, protruding out the grille & got a reply from Col as he had done it protruding out the back of the bonnet. I had a look at his gallery pictures to see if he had one, it was there I saw a parts diagram of the buffer (which I have been looking for for a few days with no success). When I clicked on to it I saw it had come from you, so searched your name & posts & found the picture (I should have been a detective |
No problem |
Peachy, Ref Ctek, I also use the croc clips, but as the car isn't used much (6000 miles in 3 years) I was wanting to use the traffic light connector & have it sitting unobtrusively in the grille, then I will just plug in ctek when required without having to lift the bonnet. The ctek will be shared between the Sport & my F type Jag convertible which is used even less & is in hibernation till a sunny day in the spring |
Parts are £10 each - free delivery from Dan - plenty of stock |
Peachy,
Parts arrived this morning. Thanks Dan for the fast despatch. Looks like an easy fit, one locating pin & some double sided tape. |
2015MY Range Rover Sport
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Prior to Vin. EA324041 they were a different part numbers, but they has been superseded to the same numbers as the current one's, there may have been a difference with in the earlier part though. Does the extra length not just fit up under the piece of plastic windscreen scuttle out of the way or are you referring to the piece which goes towards the outer edge of the wing ?.
Lindab - I had the same as you - I made mine fit - I will post pics later today - by the way there is something about these deteriorating in Topix & may be replaced as a warranty issue |
Crisis over |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595
Looking for a pair of these under bonnet buffers myself and also offside rear rubber that sits in above the quarter pillar moulding |
Anyone help please |
Anyone answering Duckworths messages ? |
| All times are GMT |
