| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > TDV8 Suspension arms |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | When I did mine I changed the bushes as the arms where fine and the ball joints ok. Also make sure you mark the bolts before undoing/removing so you can put everything back in the same place. With using your old arms you don't need the 4 wheel alinement after because your fitting everything back as it was. A quick way to tell is if the steering wheel is as it was.
|  Fri Dec 29 2017 10:09am |
| richtdv8 Member Since: 06 May 2014 Location: Rotherham Posts: 47      | hi, would certainly be cheaper to keep the original arms was just worried about changing the bushes.
|  Fri Dec 29 2017 10:42am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | If you have the facilities, changing the bushes yourself is cheaper
|  Fri Dec 29 2017 12:45pm |
| richtdv8 Member Since: 06 May 2014 Location: Rotherham Posts: 47      | thanks, can the new bushes be fitted with just threaded bar and a socket | ||
|  Fri Dec 29 2017 3:18pm |
| Tel02sport Member Since: 02 Jul 2017 Location: Surrey Posts: 14    | What are people's. Thoughts on polly bushes ? | ||
|  Thu Jan 11 2018 3:17pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Sure iv read on the D3 site about sus monts cracking and breaking away from the chassis after fitting prolly bushes as to harsh and all the shock going into the chassis. Personally I would fit and indeed have fitted gen bushes on mine and a few D3s 2008 G4 RRSport TDV8 current
|  Fri Jan 12 2018 10:17am |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322      | Interesting, mine has fairly crashy ride and the front wishbones have been polybushed. How much are genuine bushes? | ||
|  Fri Jan 12 2018 10:36am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Polys are not nice. Had the local motor factor in trying to sell me some this morning
|  Fri Jan 12 2018 1:01pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      |
 Bushes aren't that bad, to be honest.: https://www.advancedfactors.co.uk/front-lo...-141-c.asp 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed | ||
|  Fri Jan 12 2018 5:27pm |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322      | Cheers! I think I'll swap those over at some point, see if it helps. | ||
|  Fri Jan 12 2018 11:01pm |
| Posting Rules
