![]() | Home > General > Follow me Home Light Help |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
Switch lights off before switching ignition off... |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 ![]() ![]() ![]() |
Know the, but want to turn it off permanently |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
You can enable and disable it in the settings menu on the dash |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
can you though? Didn't think it would go below 30 seconds |
Yeah, you can turn it off completely! Unless I imagined it |
You`re correct. Headlamp off delay, min 30 secs....I thought I`d seen follow me home light setting to disable ![]() |
You were using common sense.
It`s not often I use that |
Do you know that with L320 RRS you can also set the reversing lights to come on as follow me home lights instead of or as well as the headlights? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
^^^^^ Ooooooo, how Tim. That would be handy when I park down the bottom of my drive. Steve. |
Do you mean on the fob? tried that but wouldn`t work....only headlights come on. Steve. |
Need to edit the ccf file.
Got my follow me home reverse enabled, with ridiculously bright LEDs |
I haven’t owned a L320 since 2010 but if I remember it’s in the owner’s manual. I never needed to edit any files ( wouldn’t know where to Start!) Mikey may be able to shed some light on the matter though! |
