Home > General > Brake Fluid Change
Lindab
Brake Fluid Change
My car was in for a recent 3rd year service (it has a 5 year service plan) It has only done 6000 miles. They said that as well as the service it would require a brake fluid change as this was recommended by Land Rover, but this is a chargeable item £54 & is not included in the service plan. I argued that if it was required by Land Rover it should be included in the service but they said no, its chargeable. Whats going on here, the service requires certain things done, ie oil, filters etc then they decide to add other items & charge for them. Either its service item or not. Has anyone else been charged for this & your thoughts on thi.s
2014 range Rover Sport
Post #543927 Sat Dec 23 2017 12:46pm
It's fairly normal that the brake fluid change is an extra when I used to take my jag to the dealer.
Can't be that important then can it.
Just say no thank you most of the time
Post #543937 Sat Dec 23 2017 2:42pm
Tyrefitter
When my 14 went in for its 3 year service they said it needed brake fluid changing,,I told them not to bother & when I got back home I checked it & it was in the green on my tester,so nothing wrong with it.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #543939 Sat Dec 23 2017 2:52pm
Stevepd
Andy,
What tester is this? Is it something to add to the toolbox or via the facilities at work?
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #543943 Sat Dec 23 2017 3:34pm
ChunkRRS
Scotland
No brake fluid changes included on a Land Rover service plan?
Are they caring even less about customers than usual?
I didn't know they weren't included that's pretty harsh IMO
Post #543946 Sat Dec 23 2017 3:52pm
Paddi
Re: Brake Fluid Change
You should check the terms and conditions on the service plan. I can't find the complete document online but the Land Rover website blurb says Service Plans cover the cost of ALL SCHEDULED SERVICING. If the service schedule requires a brake fluid change then it's black and white; the cost should be covered by the plan.
Go on - kick up a fuss - you have been ripped off. 2008 MY Java Black TDV8 HSE
Post #543948 Sat Dec 23 2017 4:09pm
ChunkRRS
Scotland
After reading this post I decided I wasn't having it, emailed my dealer and got an answer for you.
All scheduled service items are covered (apart from wear and tear items) so brake fluid changes are 100% covered by the plan. I suggest the technician has confused brake fluid with brake discs/pads.
Definitely go back and ask for money back
Post #543955 Sat Dec 23 2017 6:30pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Is this the same for non service plan services, where I'd expect if it is on LR's 'to do' list then it would be done as part of that service? Or do dealers get to cherry pick what they want to do according to the price payed? And on this I'd be expecting that fluids whether brake fluid or oils were covered within the service price?
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #543961 Sat Dec 23 2017 8:31pm
Extract from Service/Maintenance Sheet, note item No.9 asterisk get out clause. It's also stated in the Service History Book, this is for a RRS1 not sure about RRS2.
Adjust/Lubricate/Replace - Labour cost included in scheduled time except items marked *
Check - After the checking procedure, cleaning, adjusting, repairing or replacing is subject to extra labour and material cost.
8. Inspect brake pads for wear, calipers for leaks and disks for condition
9. Replace brake fluid (Every 3 years)*
col
Post #543962 Sat Dec 23 2017 8:51pm
Tyrefitter
Stevepd wrote:
Andy,
Steve.
This is like mine Steve.
ChunkRRS,,you say the brake fluid change is covered under service plan.? When my14 went in for service in July They wanted to charge me around £80 to change it.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #543973 Sun Dec 24 2017 8:56am
Bill Portland
Just waiting for the day when they say that oil is a wear and tear item and therefore not part of the service plan. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #543976 Sun Dec 24 2017 9:31am
Why do people insist on using LR dealerships for servicing? The plans are obviously a con as they work hard to charge for everything other than the oil and filter. The work done will doubtless be substandard too so they'll be doing bad things to your vehicle in the name of servicing.
Cultivate a relationship with a decent indie. Someone who cares about the work he does because it's his name over the door. LR dealerships don't deserve your time or money. Avoid them like the plague. 2012 SDV6 - it's missing a couple of cylinders
Post #543995 Sun Dec 24 2017 3:26pm
insiorc
Of course you're right, an indie probably does perform a better service.
I wonder how LR's 'goodwill' towards a broken crank would go when not using an approved service centre?
Post #544020 Sun Dec 24 2017 9:26pm
Disco_Mikey
No better or worse than a full dealer history, it would seem Rolling Eyes
Post #544024 Sun Dec 24 2017 11:00pm
Smarttech
Was told brake fluid needs to be changed every 3 years and mine is due to be done. I only phoned up to book it for an MOT.
It went very quiet on the other end of the line when I said the car is only just 5 years old and when I was at school 3 + 3 made 6 so surely it's not due till next year.
I'm guessing the main dealer needs some work ! 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #546316 Sat Jan 20 2018 7:08am
