![]() | Home > General (L494) > New 3 litre engine |
Was lead to believe it was still the V6 diesel, as is currently in the D5/405/494 |
I thought the new Ingenium’s are all “straight” engines to reduce production costs - everything starts with the 4 cylinder engine and they bolt on the additional cylinders as needed? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154
Isn't the DS a transverse engine installation? If so, fitting an inline 6 will be very tight if not impossible. 2012 SDV6 - it's missing a couple of cylinders
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
I think it’s the discovery van not the DS,,but I could be wrong.
| Chugga90 Member Since: 25 Aug 2014 Location: Bucks Posts: 34
Straight six used to be fitted in Freelander 2, which was similar chassis/floorpan.
| kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 |
The existing 2.0 SD4 or 3.0 TD6 are the only two engines available for the new Discovery 'Commercial'... SOLD - MY16 SDV6 Autobiography Dynamic - Fire Engine Red, Fixed contrast pan roof, TV, Dual Screen, 5+2, Privacy, Noble paddles. |
| warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234
No. Discovery, New Defender, Range Rover Sport and Range Rovervare all on tge D7u platform, which is the “north/south” engine and transmission (D8 platform, discovery sport, evoque and I think F-Pace) are in the D8 platform, which is the “East -West” transmission (xF is on tge D7a platform, a less aluminium version of the D7u, also north-south) Straight six version of the ingenium engine has been on the cards for a while, but had to gave more work to take out tge crank whirl issues Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
OP said Disco Sport, hence the transverse question. If he meant FF Disco then fine, i6 would be possible. 2012 SDV6 - it's missing a couple of cylinders
| timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 391
I was being a bit of numpty, read the press release too quickly. It referred to Ingenium 2.0 SD and 3.0 TD; I assumed both were Ingenium engines but it seems it is the V6 and in the Disco not DS. I'm busy writing out my 500 lines now |
| Chips Member Since: 09 Nov 2017 Location: Shropshire Posts: 125
Amazingly the commercial is 3k more than the equivalent with seats ! Given that on a business lease you can get half the VAT back on a standard one anyway you would be saving naff all getting a commercial one over just putting a load liner into a standard one and giving you the option to carry passengers when needs be . |
