Home > Technical > Restricted Performance 3.0 SDV6
Rich89
I have a 2011 RRS and its come up with restricted performance and the fault is;
P0488 - Exhaust gas recirculation throttle position control range/performance.
Is this likely to be a faulty EGR or maybe even the DPF?
Its done 60k and has been a mix of driving.
Thanks
Post #517231 Thu Feb 09 2017 2:40pm
asdfgh
Hi have the same, what fixed it?
Post #543335 Thu Dec 14 2017 12:32pm
DrRob
Sounds like EGR stuck. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #543341 Thu Dec 14 2017 1:28pm
asdfgh
Yes, what I thought, but 2 new egr's and throttle valve and it is still the same.
Post #543354 Thu Dec 14 2017 4:12pm
Could be an ECU issue then. Sad 2012 SDV6 - it's missing a couple of cylinders
Post #543370 Thu Dec 14 2017 7:22pm
asdfgh
Thanks for the quick reply.
Was just wondering if there were any 'curve ball' issues with this code ie something unrelated causing this as otherwise it is indeed looking like an ecu. Thumbs Up
Post #543379 Thu Dec 14 2017 8:04pm
asdfgh
Any further ideas/guesses?
Don't mind how crazy or far fetched? Very Happy
Post #543505 Sat Dec 16 2017 1:35pm
Paddi
How much faith do you have in the establishment that installed the new parts? I seem to recall cases where EGRs were damaged during installation or not fitted properly.
The P0488 code is only a generic code so scanning the vehicle with a LR specific tool might reveal other codes giving you more insight to the problem.
Wiring faults are more common than ECU failure so checking continuity of all related wires and connectors and earths is always recommended.
There is a well regarded independent specialist an hour away from you in Shepton Mallet: http://www.tandsnorman.com 2008 MY Java Black TDV8 HSE
Post #543507 Sat Dec 16 2017 2:33pm
asdfgh
Many thanks for the update Paddi Thumbs Up
Post #543508 Sat Dec 16 2017 2:37pm
