Home > General (L494) > Low Battery Warning MY2014 -dash cam issue?
BigBen
Had the above warning appear today and given the vehicle is only 3 1/2 years old was surprised. This has coincided with having a 2 channel dash cam fitted last week and which operates in parking mode so has a permanent live connection to fuse box but supposed to shut down dash cam if battery voltage drops to 12v. (Power Magic Pro control box on a BlackVue 750s system)
Any advice as to likely cause would be welcome. If need a new battery then any recommendations also gladly received.
Post #543359 Thu Dec 14 2017 5:08pm
jimbg
I would say 12 volts is too low?
 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #543366 Thu Dec 14 2017 6:15pm
wilf
12V IS too low - that indicates a deeply discharged battery. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #543384 Thu Dec 14 2017 7:54pm
Tim in Scotland
You can also get the “low battery” message when the battery for the Stop?Start system is low which could be a problem with the very low (for the UK) temperatures we have had recently so check that battery out too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #543388 Thu Dec 14 2017 8:22pm
Tyrefitter
I used to get the message regular on my14 AB sdv6 when I had my camera hardwired,,like Tim says it’s probably the smaller stop/start battery that’s flagging the low battery message up.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #543394 Thu Dec 14 2017 8:56pm
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I get this too, what voltage should you set the better saver to?
Post #543398 Thu Dec 14 2017 9:21pm
Eaters
I reduced the built in voltage checker on my Thinkware 770 to 11.9 volts recently and started to get low battery issues. I’ve now increased the min voltage to 12.2 and the low battery issue has gone away. After very cold nights recently, I’ve stll been able to use the remote FBH without problem, and whilst when I come to start it, it is slightly sluggish, never the less it has consistently started. And I’m using an 18 month old battery that I thought I’d Censored recently following an alternate tor failure. So all in all good news. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543407 Fri Dec 15 2017 12:13am
Tim in Scotland
Eaters, if cold mornings make for sluggish starting try giving the car two cycles of glowplug warming before starting the car. When my Defender’s battery was getting too old (I stretched it’s life out to 20 years!) that worked a treat on very cold mornings and no FBH system to run. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #543416 Fri Dec 15 2017 9:01am
Eaters
Thanks Tim. I’ll give that a go. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #543417 Fri Dec 15 2017 9:54am
BigBen
Thanks all for the replies. I tend to agree that the cut off voltage at 12v is too low but the only other option on the Power Magic Pro is 12.5v. There does not appear to be any intermediate setting. At 12.5v it sounds as though the system will shut down the dash cam very early so will defeat the object of having a parking mode especially on extended parking times.
Hope that it is weather related and to the smaller battery. So will stop using stop/start and see what happens when weather warms up and had battery check. Have not had the warning again and temps are better now and had chance to give the vehicle a reasonable run.
Post #543422 Fri Dec 15 2017 11:03am
jimbg
How long do you need to leave it for?
I have a small boat with an electric start outboard and a car type battery. It keeps a charge for days if not weeks with a small bilge pump cutting in to empty the rain.
I would have thought 12.5 should not be a problem unless you plan to leave it for several days without starting or charging.
Try and it and see? 2026 P460e Autobiography on order
2006 HSE
Post #543424 Fri Dec 15 2017 11:09am
BigBen
Can be left 7 days or more. Plan to try one of these AA solar panel trickle chargers that connect to OBD port if batteries check out okay.
Post #543425 Fri Dec 15 2017 11:33am
