Home > Maintenance & Modifications > RAI Anybody tried these?
qcnr
Norway 2007 Range Rover Sport TDV6 HSE Lux Buckingham Blue
I realise it isnΒ΄t a full blown sealed snorkel, but could do the job in an accidental dip...
https://www.ebay.co.uk/itm/NEW-Air-Intake-...1438.l2649
Post #542899 Fri Dec 08 2017 11:37am
garrycol
Australia
Looks basically the same as a factory RAI and has the same limitations.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #542903 Fri Dec 08 2017 12:01pm
Buckster
As garrycol says, basically a chinese copy of the original Land Rover product 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #542908 Fri Dec 08 2017 1:16pm
HughN
Wales
Garry
What are the limitations? It must cause mpg to drop.
cheers
Hugh
Post #542920 Fri Dec 08 2017 3:54pm
Limitation is that it is not a snorkel (as they suggest). It is a raised inlet intended to pull in clean air instead of dusty air. The device isn't water proof. Even if the device itself is waterproof, the hose within the vehicle's wing isn't and so water can get in.
You can make a waterproof system but then you just get deeper until you kill the electrics or you float off downstream, never to be seen again. 2012 SDV6 - it's missing a couple of cylinders
Post #542946 Fri Dec 08 2017 7:55pm
Buckster
HughN wrote:
Garry
cheers
Hugh
Whats MPG Whistle Laughing 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #542948 Fri Dec 08 2017 8:04pm
HughN
Wales
I'll manage without one then. Thanks.
Post #542981 Sat Dec 09 2017 8:09am
HughN
Wales
"milliseconds per gallon"
Post #542982 Sat Dec 09 2017 8:09am
