![]() | Home > General > Sport won't start. |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
Welcome to the forum.
| Mikey v8 Member Since: 27 Nov 2017 Location: Tamworth Posts: 8
Yes the battery was fully charged and he cranked the engine over and over and it didn't die, the fault code logged was P0193 which he says is fuel pressure sensor but he says he doubts it that! |
Quick update, there's no fuel even getting to the fuel filter, so the tank is being dropped next week, logically you'd think its the tank pump but that was only done 6 weeks ago! Surely they won't fail so soon? It was a brand new genuine part, I'm at a loss to what else the problem could be..... |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420
Have you checked fuse number 1 in the engine bay fuse box? |
| Ste815l Member Since: 22 Sep 2017 Location: Newcastle Posts: 30
Could be the in tank fuel pump solonoid. Best way is to get under car near tank and put your hand on tank cover get someone to switch ignition on. Listen and feel for pump priming will last 10 seconds. If nothing then it's either fuel pump has failed or it's not getting power. If you can hear or feel it priming then it is the fuel pump solonoid it's failed and closed. |
Yes checked the fuses. |
Now you mention it I've not heard it prime the system, so the solenoid, is that not part of the pump? Or do you replace that separately? |
The solonoid is and isn't part of a new pump. If you replaced the pump in its carrying case and all new fuel lines then yes the solonoid would be new. But you can open up the pump case and just replace the pump only this is the cheaper option. But a fuel pipe has to be replaced and the negative charged wire that goes to the solonoid has to be cut and re wired if this has come loose then the solonoid will close and not open till it gets a negative charge. |
Ok, this is something I'll check when the tanks off👍 |
Just to update and end this thread, the fault was the tank pump, so replaced the whole assembly this time, this is the 2nd pump in 2 months! Just hope this one lasts longer. |
| All times are GMT |
