![]() | Home > Technical > Folding mirrors. |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
The dam things work their way further and further down on tilt so best to turn that function off !
There is an easy way to fix the driver’s door mirror - set the reverse dip position for that mirror to be the same as when driving forward then it won’t seem to dip...... I have always set mine up that way 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
Hey Tim....you mean when setting the memory settings yeah? Steve. |
Select R, adjust both mirrors to your preferred settings, back to P or D, no need to press the memory button, that is for going forwards with different drivers using the car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Ah yeah.....I got you |
Nope, that doesn`t work |
| phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198
When I bought my 2005 RRS, the passenger mirror dipped whenever I selected reverse (which I found annoying).
| LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209
Whenever I park and turn the engine off then lock the car, my driver mirror spazes out and points whatever way it wants to. I have to reset it everytime I get back in the car. Noisy black one |
Thanks, I`ll give that a go. Steve. |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
What happens if you simply turn the dipping feature off completely in the settings menu on the stalk ?.
I assume they won`t dip! Steve. |
No they won't dip, that's the object of the on or off setting, so what are you trying to do make the n/s dip and o/s remain stationary?
| All times are GMT |
