![]() | Home > Maintenance & Modifications > Rear callipers. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I now need 2 rear brake callipers as mine are siezed. I`ve emailed Dan at Duckworths but I`ve also looked online and found refurbed ones for around £100 a pair...would they be ok to use.....?
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
These are the ones I had put on.
So £125.60 with the £60 off for return item? They must refurb them then. Steve. |
No home delivery |
That`s my worry now, I`ve just had new discs and pads...need to sort soon. Steve. |
Just don't drive it and make it worse Noisy black one |
I won`t need it till Saturday but then I need it for work. Steve. |
Über Noisy black one |
I think best bet will be Euro Car Parts cos I could pick some up tomorrow and maybe get them fitted by the end of the week |
How do you know they are seized? Unless the brakes are getting very hot it may be less of a problem than you think and hence not quite so urgent? Most of the braking effort is created by the front brakes after all. If you have a good motor factor nearby they should be able to offer you new calipers or remanufactured calipers at a decent price instantly or with next day delivery. All the calipers probably need is dismantling, cleaning and reassembling with new seals. Unfortunately most if not all garages can't be bothered with that 'old school' approach and just want to slap on a brand new pair. 2008 MY Java Black TDV8 HSE ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
I purchased a brand new rear one off ebay for £40 !
Hi Paddi. When he fitted the discs and pads a while back he freed them off. I asked him to investigate a squeak and that`s when he saw they were seized again. They were getting hot, you could smell them |
He did have a good look and didn`t see anything obvious which would cause it...ie crud etc. Steve. |
I guess you need to know where to look. |
