![]() | Home > Technical > Silly season starting! |
| GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143
Well, just as I thought I was doing well with the RRS regarding trouble free motoring, my smugness has turned round and bitten me!
Sounds like it's already jammed... |
If it’s jammed, what does that mean? |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
jammed.. stuck/seized and needs fixing |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Needs to be released and then brakes adjusted did you have to pull the emergency released or is the car still derivable ie handbrake not stuck on if it isn't don't use it till it till the shoes get adjusted/changed |
Hi Geoff, I pulled the emergency release cable and then used car for a bit but the red light was flashing and warning that no park brake was available. Tried to put it on when got home and screeching again and locked on. Wasn’t going to use it so didn’t bother with release cable again |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
I think you were lucky to be able to unlatch the brakes with the cable release,,,, I wasn't! . You should have taken that opportunity to have the brakes serviced and certainly not attempted to use it again until repaired for risk of causing more damage. 2010 RRS, TDV8
Hi, thanks for replies. Not sure i understand what you mean by lucky! Hardly call passing the mot at 10.00am then handbrake failing at 15.00pm lucky! Also, the emergency release is just that, a manual release. It took the shoes away from the drum hence allowing it to rotate freely. How is driving it going to cause any more damage? i didn't, like some owners, rock the car whilst using auto box to go forwards then backwards to free the shoes off. Was i so wrong in using the car and parking on level ground and using park for brake. Even local indy said they didn't need to send recovery vehicle out and i would be fine driving it there!" |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
I maybe wrong here but I think gogsy meant you were lucky that the release cable worked, quite often they don't judging by previous posts from members.
The assumption was not to use it after it squealed initially, and have it repaired before using the EPB again, so the emergency release wasn't needed |
Hi, I understand that in an ideal world, as soon as the screech occurs, the car would be raised, stripped, cleaned and adjusted. But what I am trying to get my head round is what is the implication of me using the manual release, and how does that complicate me just stripping, adjusting etc now?
As Dm and Col noted,, my comment was more towards not using the Epb until it was sorted,, not so much the car. I was unfortunate to be in your position a few months ago on the morning I was travelling to the airport, Epb jammed, emergency release did not work had to get it trailered to an indie,, even cutting the cables would not release the rakes. Cost me new Epb, discs, pads, shoes etc so to be honest I still think your lucky!.
| Roy_RRS Member Since: 11 Nov 2017 Location: Peterborough Posts: 11
I had the same thing on my TDV6, only a week apart. It went through MOT fine, pulled up at a petrol station a week later to find the E park brake had jammed on solid. Same screeching noise as yours was doing.
Ok, late update!
| All times are GMT |
