Home > Technical > Oil leak!
GARYF123
Oil leak!
Hi everybody!
I have a 2007 2.7 TDV6. I had a oil leak that i traced to the hose attached to the top of the turbo. I managed to cure this but i then discovered another leak. After removing the metal undertray and cleaning up, it appears to be coming from the sump pan, or rather the gasket. The engine was replaced about 2 years ago and looks very good from underneath (sump not corroded). Does the sump have a gasket or is it a sealing compound? Any problems to overcome when changing?
Thanks in advance,
Gary.
Post #540580 Sat Nov 11 2017 8:00pm
Gasket but they aren't cheap!!
Actually meant to be reusable gasket.
Reused mine twice
Post #540581 Sat Nov 11 2017 8:02pm
GARYF123
Ok, thanks Andy!
Post #540582 Sat Nov 11 2017 8:21pm
GARYF123
Whilst I am on with my maintenance, can I also ask for advice on the following:
I am getting the usual Amber suspension light soon after start up and cannot raise or lower until I turn ignition off and restart. This cycle then keeps repeating.
I had the codes read and got - C1A20-64
The Hitachi compressor was replaced for the AMK unit 2 years ago along with the relay and software update. I have sprayed leak detector around the compressor and reservoir but found nothing. I sometimes get the 'raising slowly' notice. Could the Compressor have gone in such a short time? Can the drier contents be replaced on the AMK?
Any other ideas on what to check?
Thanks,
Gary.
Post #540591 Sat Nov 11 2017 9:05pm
Sorry. Don't know about amk compressors
Post #540593 Sat Nov 11 2017 9:17pm
Johnski
Compressor is quite the normal thing, but it can be a very small hole in the pipework and which can be very difficult to find.
Besides the other suspension things that can go tits up, like the bags etc it does sound like you have a slow leak causing your problem, just hope not the compressor as not cheap, or even a combination of the two things. Whistle John
Post #540603 Sat Nov 11 2017 10:46pm
Thanks,
Gary.
C1A20-64
Pressure Increase
Too Slow When
Filling Reservoir -
Signal plausibility
failure
Signal plausibility failure
Gallery pipe air leak
Air supply unit fault
Reservoir pipe air leak
Reservoir air leak
Intake filter
blocked/restricted
Intake pipe
blocked/restricted
Air suspension intake
silencer blocked/restricted
Corner valve stuck open
Where available, refer to the guided diagnostic routine for this DTC on the approved diagnostic system. Check the
Air suspension intake pipe and silencer for blockage/restriction.
Post #540605 Sat Nov 11 2017 10:57pm
