Home > In Car Electronics > Head unit and nav
Page 2 of 3 <123>
geoffsnook
Bow down Thumbs Up
Post #537551 Fri Oct 06 2017 4:34pm
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Had it confirmed today it’s the amplifier that has gone
Can anyone let me know how to check model without removing the amp to look at label
Are they colour coded on the top ie mine is silver and I’ve seen some black ones on eBay
My iid tool just say aud2c fitted
What would be recommended a new or used amp as big price difference ie used about £200 and new around £700 or can they be repaired
When fitting a new amp do they need to be coded to the car
Thanks for any help
Cosmo
Post #540455 Thu Nov 09 2017 7:53pm
geoffsnook
Try mmj on here they are breakers who sponsor this site go for second hand from them if they have one or another breaker unless you have a wad of cash burning a hole in your pocket Rolling with laughter is it logik 7 or just normal Harmon Kardon Thumbs Up
Post #540457 Thu Nov 09 2017 7:58pm
Cosmo15555
Normal
Post #540458 Thu Nov 09 2017 8:03pm
geoffsnook
You should be able just to buy one and change it over but to be sure if its not working take it out and check the number to be sure but i am pretty sure they are all the same as long as its just Harmon Kardon Thumbs Up
Post #540459 Thu Nov 09 2017 8:07pm
Cosmo15555
I’ve noticed a couple different model numbers on eBay so I’ll remove to check mine
Thanks for your reply
Post #540460 Thu Nov 09 2017 8:09pm
geoffsnook
There not hard to get out but make sure the people on ebay accept returns mmj are on there as well Thumbs Up
Post #540461 Thu Nov 09 2017 8:12pm
Cosmo15555
Amp arrived today fitted but not working fault code now is
U2003-31 (2B) Fibre optic communication bus - Frequency modulation/pulse width modulation failure - no signal
When I plug live feed into amp ther is red light from where the fibre optic lead plugs in but goes out after about 30 seconds
I have checked the Bluetooth module but no red light coming from cable
The fibre optic cable that plugs into the amp has red light all the time
Any help would be appreciated
Thanks
Cosmo
Post #540858 Tue Nov 14 2017 7:36pm
Cosmo15555
I spoke to rangerover dealer today they told me amplifiers are coded to the car so second hand amp won’t work in my car
Can anyone confirm this or has anyone fitted a secondhand amp in there car
Thanks
Cosmo
Post #540976 Wed Nov 15 2017 8:00pm
Cosmo15555
Second amp arrived today same problem fibre optic failure
Done a bit of searching on net some links to TMC so I connected my fibre optic lik cable to this and now stereo working
I have to get new test lamp to see if power going to TMC
If no power can I link a cable from a red wire that connects to Bluetooth module
Thanks
Cosmo
Post #541583 Tue Nov 21 2017 10:44pm
geoffsnook
It may be the tmc part itself unless the fuse is blown then there should be power there unless you are unlucky enough to have a break in the wire Thumbs Up
Post #541615 Wed Nov 22 2017 5:01pm
Cosmo15555
Just tested power lead all ok so unit needs replacing
Thanks for the reply
Post #541616 Wed Nov 22 2017 6:47pm
geoffsnook
Post #541619 Wed Nov 22 2017 8:08pm
Cosmo15555
I managed to buy a used TMC from eBay for £21 delivered now all sorted
Thanks for all the replies
Cosmo
Post #541791 Fri Nov 24 2017 10:17pm
geoffsnook
And how much and what sis the stealers say Rolling with laughter Thumbs Up
Post #541797 Sat Nov 25 2017 5:49am
Page 2 of 3 <123>
