![]() | Home > Technical > Suspension issue. |
Well i would think that if it was a broken wire then it would show as a fault straight away such as a loss of power which it is not but you know where i am going it may even be a speed sensor or steering angle sensor |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I`m sure I saw steering angle sensor as he scrolled through the list actually. Steve. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Hi Cymruambyth,
Nice one, thanks for the offer |
That will throw the dsc light sometimes it can just be reset the and its fine usually needs doing after any work to the suspension |
The garage has had it since 9am yesterday and still hasn`t found the problem |
Ok....picked it up. He says it`s a canbus issue but because it`s so intermittent I need to let it get worse to find it. He`ll then need it in for about a week so he can go through the whole loom as he seems to think it may be a break in a wire!
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
Sorry to read all this!
I didn`t think the rears were Brembos.....just the front |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
rears aren't brembo 4 piston. |
