![]() | Home > General > Black smoke |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
If you're losing power in low gears it's probably the same as mine... split turbo hose. Others on here will give useful responses. Barrie.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Split turbo hose? Not in a 4.4 bent 8 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9095 ![]() ![]() ![]() |
Black smoke suggests the engine is running rich. You need someone to check for error codes to see where to start with it. Could be an injector issue, MAF issue etc. Might be worth checking/changing the air filter just in case it's heavily contaminated and thus partially blocked. 2012 SDV6 - it's missing a couple of cylinders
I will leave it to those who know more about these things than me. |
It can only be the 4.4 Petrol as his avatar shows a 2005 V8, 4.4 Sdv8 only came on line in 2013/14. I don’t think the 4.4 V8 has any turbos, it is a naturally aspirated Petrol 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim. Now I know. |
Josb1990 Member Since: 02 Nov 2017 Location: Southampton Posts: 2 ![]() ![]() ![]() |
Sorry it's a vouge 2003 |
The 4.4 V8 petrol is a rare thing in the RRS. You might have more luck in the Range Rover forum: http://www.fullfatrr.com/forum/ as there are more likely to be more of them with knowledge of the engine.
Then it will be a Vogue L322 Range Rover as Sports only started production in 2005. The V8 petrol in the FFRR is a BMW unit at that stage of production so also BMW forums will be able to help. Good luck with getting it sorted, as mentioned FullFatRR forum is a great place to start. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
