![]() | Home > General > Head and Rear lights - up grade?!? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5058 ![]() ![]() ![]() |
I don't think the headlights can be done, as either the bumper or wing needs changing too. oh and grill
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 338 ![]() ![]() ![]() |
Thanks for yours and the info. The model that followed the 2006 Sport that was fitted with LED lights - do you think there is any chance those lights would be compatible with my 2006 model without changing bumpers etc? Andrew Kennedy |
Rear = Yes
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...1438.l2649 Steve. |
How can these trade sellers not check (proof read) and get the spelling right for different models. Not very professional, Vogue misspelt for example. |
It`s only a tpyo! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
John' If you really want to be really picky it was not vehicles produced after 2012 that had to have DRL's by Law either, but New Models first type approved after early 2011 if I remember correctly. ![]() Cheers Col |
And the facelift RRS didn’t have DRL’s it had “styled” led headlight surrounds that cannot be made into DRL’s without quite a lot of hard work! I had Hawke remodelled headlights with a line of LEDs under the adaptive lamps on my 2007 TDv8. They were not cheap and in the next 3 years of ownership several of the small LEDs failed and couldn’t be replaced......
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
I added rings to my old one.
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
I had mine made in 2012 by a guy in Bradford, fitted SMD rings to all 3 sections. These are on 100% of the time that the car is driven. Well over 30k miles done, and there’s no fade, no loss of smd’s. The only issue I had was in summer time a few years ago, the heat unstuck the sticky pad securing one of the rings, so off it came into the oven, opened up the headlight, a few squirts of resin and been fine ever since.
