Home > Faults & Fixes > Rear parking sensors
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
There are a whole host of topics on this, with fixes and deviations from the topic and boat loads of info.
I'm selling my RRS and for a while the rear sensors have not been working (i have no front sensors). Not having them working hasn't bothered me. But obviously it will bother the person who intends to buy my car.
When starting the car there is a long beep and the button for PDC flashes. I've stuck the car in reverse and wedged the brake and can hear no audible output from any of the sensors.
Would this imply a loom failure over all 4 sensors being duff?
Is it an easy fix to replace the loom?, rear bumper off etc. Winter is setting in so ideally want to now get it done before the cold comes on.
cheers
Steve 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #539168 Wed Oct 25 2017 11:56am
Paddi
Try first taking the rear bumper off and having a good look at the condition of the loom. If there are any obvious breaks solder in a new section.
Here is a link to bumper removal:
There are other linked videos by Powerful on other bits of the parking sensors.
A decent fault code reader would be a great help. It seems to be necessary to clear the fault code before the system will work again - that's what I found with the fronts anyway!
In my case, intermittent fault of the front sensors seems to have been solved (so far!) by just removing the front bumper and cleaning everything up (including all the sensors and connecting plugs) - the loom all looked OK. 2008 MY Java Black TDV8 HSE
Post #539173 Wed Oct 25 2017 12:49pm
Pakolainen
Thanks
Reckon i know what i’ll be doing in the weekend. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #539197 Wed Oct 25 2017 5:28pm
Eaters
I think you posted some concern with your parking sensors before and I did paste a post of mine in case it was of any help. See below in case you missed it.
http://www.rrsport.co.uk/forum/topic48459.html
It’s certainly worth getting the bumper off and having a look. As I found that a prior owner had already bodged a repair I concluded that there may be a fault with the routing of the wiring loom that renders them susceptible to damage.
The fact that you can’t hear anything from the sensors suggests a power failure rather than a sensor fault. Check that red wire. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #539208 Wed Oct 25 2017 7:16pm
Pakolainen
Thanks. Will get onto that. It's snowing now so might slow me down. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #539228 Thu Oct 26 2017 6:50am
Socast
Just as an FYI, my rear sounder unit failed a couple of months back. This presented with a dash fault saying the front parking sensors weren't working (I'll repeat, it was the REAR sounder that failed), I had no sensors either front or rear until I replaced the sounder unit. So that could well be worth looking into (especially as the sounder is either £12 or £15).
As you're selling the car it doesn't really matter as much, but if it is a parking sensor that's faulty, the cheap after market sensors have a smaller detection range than the originals, so it's worthwhile spending a little extra.
Post #539236 Thu Oct 26 2017 9:00am
Pakolainen
hmm, i don't have any dash warning messages about them not working and no front sensors either. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #539313 Thu Oct 26 2017 3:03pm
Eaters
From the manual:
"If a long, high-pitched tone sounds and the switch indicator flashes when PDC is activated, then a fault in the system has been detected - first check that the sensors on the bumpers are not obscured by dirt, ice or snow. If the fault persists after cleaning the sensors, contact your Land Rover Dealer/Authorised Repairer for assistance."
Yours are the same symptoms as mine (except I had front sensors as well - which were not broken).
Sounds to me like you need to get out in that snow Robin
Gone:
MGZTT 190 2.5
Post #539323 Thu Oct 26 2017 4:13pm
Pakolainen
I guess it can pay to regularly check these things.
I find a random biolet piece if wiring going from the main socket and then around the metal frame of the car and then taped onto the yellow wire of the second sensor.
Also found 3 of 4 sensors caked in half a kilo of sand and dirt. Each.
Mazda 3 1.6 2010
Post #539571 Sun Oct 29 2017 9:42am
Eaters
Aha. So it shows that mine is not the only one with a bodge job around the rear sensors.
Looking at the photos I took when I did mine may give you a bit of help in understanding how it should be wired. See my gallery. It looks like the first sensor has brown black and red wires.
Hope you get it sorted Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #539617 Sun Oct 29 2017 5:37pm
Pakolainen
So, carrying on from previous post. Wiring loom looked to be ok. applied new tape over the violet wire that seemed to circum-navigate the yellow wire to sensor 2. Let the bumper dry and hoovered all the crud from its inside.
Re-inserted the plugs and the wiring. Attached main plug from loom back to the other part.
Car on, R selected. long high pitched beep and continual flashing still.
Does it need the use of an IID Tool to clear the fault before it works again (thinking that's my easiest option - go to local garage and get them to read and clear faults) - would that also for sure tell me what the fault is.
I've read a lot of corroded wiring looms, or an individual faulty sensor.
Would rather pin point the fault that spend the cash to change everything. Especially when i'm looking to sell it.
cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #539717 Mon Oct 30 2017 6:04pm
Eaters
That maybe the best answer. At least to eliminate what you can for minimal cost. Does it look as if the violet wire has been used to replace the yellow one? If so, I don't thing that would explain the others not working. I'm guessing that the red green yellow and blue wires are the return signal to the parking module (see wiring diagram below) with brown and black providing power and earth. But as you say, there may be a fault recorded which needs to be cleared - although I had no issues with mine. After repairing the red wire it just started working again.
http://www.rrsport.co.uk/gallery/albums/us...ensors.pdf Robin
Gone:
MGZTT 190 2.5
Post #539752 Tue Oct 31 2017 9:18am
Pakolainen
Bluetooth OBD reader bought. Green ticks all the way flthrough on the scan. No fault codes to read or clear.
So whilst that is all good. It’s also a bummer as i still do5 know the issue. So looks to be a new wiring loom.
Ebay for 50 GBP plus postage.
Cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #539767 Tue Oct 31 2017 11:23am
Paddi
Which OBD reader are you using? If it is generic only then doubt it would read the all or any of the sensor codes.
After two weeks with no sensor problems I suddenly got the erratic constant beeping when selecting reverse (no flashing light on the dash). Plugged in the IID and the instrument panel module had logged a U code 'lost communication with park assist module'. Cleared the codes and now all hunky dory again until the next time I suppose. It seems some codes have to be cleared to get the system working.
Post an update on how you get on with fitting the replacement loom!
In my case guess I'll just have to do some more investigation Crying or Very sad 2008 MY Java Black TDV8 HSE
Post #539912 Wed Nov 01 2017 6:04pm
Pakolainen
The OBD reader is a bog standard bluetooth module. Cost 40€.
Gave the following diagnostic results:
Still get the long pitched beep and flashing lights.
Will look at a new loom.
And the car must be in a bad mood with me as now the windscreen washer jets on the bonnet don't squirt. Only the head lamps work. So need to dig into that now as well. Should never have told her i was going to trade up.
On a side note, i haven't bought a car from the UK in over 23 years. What's the current format for buying a car in terms of - tyre's have been kicked, breath drawn through teeth and a few tuts. How much haggle is acceptable nowadays?
Mazda 3 1.6 2010
Post #539955 Thu Nov 02 2017 9:05am
