![]() | Home > General > Whip crack away |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2020 ![]() ![]() |
Make sure you get a good one - lots of threads on here. Do a search |
So I had the windscreen fitted, but today I noticed the passengers carpet is wet, so straight on the phone. A chap from the same company but the Salisbury branch had a look. The windscreen is water tight but the trim wasn't fitted right which let water in through the cabin filter and into the car, the filter was soaked. So I've complained waiting a reply.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
And if I remember rightly one key check, if possible in the current warm climate, is to check the heated front screen is working properly Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
