Home > Technical > 2010+ Range Rover Sport Number Plate Lights - Not working
AlphaBravo
Hi guys,
Not a bulb issue as I've changed them.
Can't find anything definitive but found something on the net about them being on fuse 4 in the fusebox behind glove compartment.
The table showing fuses (to me, a complete idiot) makes no sense to me but I do have a colleague with a 2007 RRS so we could do a swap and check to see if it is this, if only I could work out which one to pull!!!! 2015 BMW 435i MSport
2015 MINI Cooper
2010 RRS TDV8 (Full AB Conversion)
2002 BMW 330Ci Convertible
Post #538529 Tue Oct 17 2017 5:17pm
on early ones its on the same fuse as the left tail light.
Broken wire into the tailgate I reckon.
Try opening and closing tailgate with lights on and see if they flash/flicker
and the glass opening
Post #538533 Tue Oct 17 2017 6:11pm
AlphaBravo
Thanks for your reply. I will go and check now.
It has the newer style LED rear lights so not sure if that would be affected by fuse 4? But they are both working fine (rear lights). 2015 BMW 435i MSport
2015 MINI Cooper
Post #538534 Tue Oct 17 2017 6:13pm
