![]() | Home > General > Winter prep with new Ctek mxs10 |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello all
It is an excellent bit of kit and so easy to use. I would have put one together myself, but as I am getting fatter, balder and lazier. With two children under 5. It's nice to get it delivered complete through the post. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2018 ![]() ![]() |
Snap! Great bit of kit that tow electrics adaptor. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
I find driving 100-150 miles per day keeps the battery topped up and the FBH doesn't do for the battery even when used everyday. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
I'm sure you would get the same benefit for £65 with a 5 amp version |
LTFR Member Since: 10 Oct 2017 Location: Liverpool Posts: 3 ![]() ![]() ![]() |
Got my 5 amp ctek and 2,5m extension delivered today after reading an earlier thread on the subject which is spooky. Just need to check I've got a permanent live feed on the 13 pin socket before opting for the adaptor, its got to be easier than popping the bonnet and attaching directly to the battery.
5amp version is fine, 10amp is quicker, I was going to get the 25amp version but was not suitable for using the tow bar electrics.
A Nissan Micra will also get me from a to b ![]() Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
Depends what you are after.
