![]() | Home > Maintenance & Modifications > Leaky Sunroof - Air gap - |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Interested to know how you get on as i can see light through mine and water drips in but apparently that's normal |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
You local dealer will probably tell you it is a ”characteristic” of the car now that one person has raised it........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
You do not need to remove the headlining, the seal locates in a groove/recess in the actual sunroof panel which you will not see until you remove the old seal. Tilt the Sunroof panel and remove seal from rear of panel and part way down the sides, then open sunroof part way and remove rest of seal. To refit close and tilt panel, start in centre of panel on rear edge and work seal into locating groove, basically refit in just same way as removed old seal starting at rear working towards front. Make sure you refit the seal in the correct orientation, make a note which way round the old one is before removing it. You might also need something to push seal into the groove like some sort of plastic tool that will not damage the seal. Cheers Col Cheers Col |
| All times are GMT |
