![]() | Home > Maintenance & Modifications > 3.0tdv6 Remap without ecu removal |
If you don't use Alive or BAS as recommended then don't come crying to us |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4508 ![]() ![]() ![]() |
Yes, I have. There is a reason I became an Alive dealer ![]() ![]() EDIT: And I didn't say there was anything dodgy about them... My remap done by a non-specialist tuner. It cost me £100 less than the retail price of an Alive remap. The original remap caused me no end of reliability issues, as well as costing me over £7,000 to put the car right again, in the shape of a new gearbox, transfer box, rear diff and a set of injectors... The car was repaired, driven to Alive HQ, re-remapped by Gary, and I have not had a single issue since It's your car, it's your money, it's your choice... |
You pay your monies and take your choice |
I took my 2012 model 3.0 SDV6 to Alive shortly after I got it, so about 2 years ago. It was an ECU out job, but that said it was all done as I waited, around 3 hours if I remember correctly. Turned the car into the car it always should have been, touch over 300hp now but can't remember torque difference, around 10 to 15% from memory. Have done about 30k since, currently on 80k, and no reliability issues at all, flown through the MOT's etc. Perfectly safe to do, friendly people and I wouldn't have any problem recommending any 3.0 SDV6 owner to do likewise. |
The other point I would make is always use a specialist who is expert with the specific marque and ideally the specific vehicle. Alive or BAS for these motors. In a previous life I had a Saab 9000, and similar tales of woe on that forum about remap issues, but I had mine done by Abbot Racing Motorsport, specialist tuners who ran Saabs in racing teams, and again never an issue with performance or reliability (or hitting 90mph in 3rd, but that's a whole other story |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Sorry for the thread drift, but I've been contemplating getting the Alive remap carried out, lucky for me DiscoMikey is close by, but I was just wandering are the before and after results noticeable, I've had a couple of normally aspirated cars mapped but to be truthful apart from removing flatspots I've not really been able to tell much of a difference. It would be good to get some first hand feedback. ![]() |
It makes a huge difference to the SDV6 |
Thanks for the feedback, that's what I was hoping for. |
I agree with Disco Mikey. Mine was 256 bhp stock I think. A 20 percent uplift to circa 300 plus a decent torque boost makes a big difference.
Definitely touches gearbox as there are torque limits in place on engine map in certain gears before the map takes place. Gary at Alive talked through this with me before mine was done |
Interesting, he didn't say that to me and I thought resetting the gearbox or reprogramming it was a separate exercise ? You live and learn on here, that's for sure. Irrespective, the main points I was making about the driving experience difference after remapping and that engine and gearbox are all well within maximum tolerances are the main thing. |
I 100% agree with every part of this statement in my experience with the Alive map! And I'm now carrying a fair bit of extra weight and it still feels lively ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
The PCM and TCM both talk to each other. The gearbox determines how much torque is being produced, and can alter the engine output if it deems necessary No physical programming of the gearbox ECU takes place, but it is affected due to the Engine ECU being tuned ![]() |
The only thing I would add is you do need to give your car (mapped or not) a good run out reasonably frequently or the dpf can get clogged and you can end up losing performance that way or at worst a restricted performance requiring a forced regen. A remap cannot stop this. I give mine a good run once a month if not doing a Brum to Edinburgh return, once every three months a shot of diesel clean extreme (from halfords) and tend to use millers oils diesel supplement at a fill up. Maybe a bit anal but keeps everything clean and tidy. And I never, ever, miss a service, a good trusted local indy is worth their weight in gold ). |
