![]() | Home > Technical > Range rover supercharged |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Yes, you can turn it off at the steering wheel, but it disengages the cruise control completely it does not revert it to manual operation. If yours does for some reason it's a bonus
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
I really like ACC but you have to remember what its designed for. Its a motorway cruising aid and not really something for A roads for the reasons others have stated cos it pick up random other things and slams on the brakes. (But yes, I do use it on some A roads and in town to make sure I don't exceed the speed limit cos I'm a good boy |
| tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240
Yeah you're right about it being purely a motorway cruising aid. It works well enough for that. Just a shame it can be a liability using it on A/B roads. Toggling between ACC and CC seems like an obvious thing you'd want to do. |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
I've never used it myself (properly) but there is a button near the hazards that turns off/on forward alert (not the button for the parking sensors), This may well disable the radar on the ACC. |
Aha! So Socast, it appears that there are variations in design. Well who'd-a-thought it?
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
Oooooooo....that`s what that button does |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
I think i will give that a go as well |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322
How odd, my MY08 TDV8 (late 2007) has that button |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
http://www.ebay.co.uk/itm/Landrover-Range-...SwAyBZnvlP
Just tried my button in a 30 mph did not make any difference still had auto braking |
I may well be interpreting the Handbook wrong, but It say forward alert is active when switched on and ACC is off. It gives you the same warning as ACC without the braking aspect, it makes no mention of it turning off the Automatic side and reverting to Manual control of the Cruise Control i.e. set speed with no braking effect. If I remember correctly I always had it turned off in my old sport because I found the permanent green icon illumination in the instrument panel annoying when turned on. It made absolutely no difference to the ACC operation itself.
Balls |
| All times are GMT |
