Home > Maintenance & Modifications > MOT advisory - might need to get the wire brushes out
DrRob
This was picked up:
Fluid suspension unit supply pipe corroded but not seriously weakened Anti roll bar pipes (2.4.D.3)
Is this the block and pipes inside the drivers front wheel arch?? Wire brush, Kurust, paint and then grease me thinks to stop it getting worse.
Any thoughts / input appreciated
TIA
Rob * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #537407 Thu Oct 05 2017 1:28pm
Could be the pipes that run through the wheel arch or any of the pipes running under the driver's side cill. Time to jack it up and have a little peek. 2012 SDV6 - it's missing a couple of cylinders
Post #537411 Thu Oct 05 2017 2:04pm
Oldandconfused
Assuming you've just has it tested, why not ask the tester while it's still fresh in his memory? I'm sure he or she will be happy to talk to you about it.
Post #537458 Thu Oct 05 2017 6:03pm
DrRob
MOT was a while back. Been a lazy Censored
Now sorted. It was the pipes that run from wheel arch into union towards engine. Quick rub, bit of kurust, paint then thin smear of grease. Also greased rest of pipes back to rear axle.
Feel smug and satisfied Thumbs Up
PS 3 ton SGS jack and my 3 ton axle stands worked a treat - safety first Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #537459 Thu Oct 05 2017 6:16pm
