Home > General > RRS V Discovery3
murphy
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
RRS V Discovery3
I have been trying to find out if the RRS 2006 is wider than a land rover discovery3 and if the drivers seat position is the same height, can anyone help ?
Post #537404 Thu Oct 05 2017 12:48pm
geoffsnook
I would say having moved from a disco 3 to a RRS that it feels a bit smaller and mine is a bit lower on the drivers seat but mine is the supercharged but it is every bit as comfortable probably a lot more Thumbs Up
Post #537434 Thu Oct 05 2017 3:33pm
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
Hello Murphy,
To my knowledge, the RRS is slightly shorter than a D3, but the width is the same.
The seating DOES feel slightly lower, but I am not sure if that is because the roofline is lower and makes it feel like this.
Comfort is certainly excellent, and I agree with Geoffsnook that the RRS is probably much more than the D3.
Not sure if there is any difference between the ride height of the supercharged version and normal versions though. I didn't think there was, but I may be wrong.
Nick
Post #537537 Fri Oct 06 2017 3:32pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
RRS 2006:
EXTERIOR DIMENSIONS
Overall length:
188.5 in. (4,798 mm)
Overall width:
85.4 in. (2,170 mm)**
Overall height:
71.5 in. (1,817 mm)***
Wheelbase:
108 in. (2,745 mm)
Track, front/rear
63.2/63.5 in. (1,605/1,612 mm)
**Including side mirrors
***With open sunroof
Discovery 3 (2004–2009):
Discovery 3 (L319)
Wheelbase
2,890 mm (113.6 in)
Length
4,850 mm (190.9 in)
Width
1,920 mm (75.4 in)
Height
2005–2006: 1,880 mm (74.1 in) 2007–2009: 1,890 mm (74.5 in) Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #537540 Fri Oct 06 2017 3:56pm
nebc100
Sorry, but I have found other values for the Discovery:
Length 4,829mm
Height 1,882mm
Width (inc. mirrors) 2,200mm
Wheelbase 2,885mm
This makes is the same width as the RRS, but is lower (roofline is lower) and shorter.
Post #537542 Fri Oct 06 2017 4:07pm
geoffsnook
Did not say the supercharged was actually lower than a normal range rover sport but did say feels smaller and lower Thumbs Up
Post #537545 Fri Oct 06 2017 4:15pm
nebc100
Sorry Geoffsnook, I misunderstood you.
Post #537548 Fri Oct 06 2017 4:25pm
geoffsnook
Post #537550 Fri Oct 06 2017 4:31pm
BJH1959
No apologies needed here - just copied and pasted from LR websites. Barrie.
Post #537556 Fri Oct 06 2017 4:42pm
the suspension height calibrations are slightly different on the RRS v D3
Post #537565 Fri Oct 06 2017 5:31pm
murphy
Thank you all for the reply's
BJH1959 your answer makes the RRS wider than the Disco3 by 250mm (10 in)
nebc100 you make them both the same width
I have found some spec on Parkers which make the RRS 2170 wide and the Disc3 2190
so I think the best thing to do is sit in a Disco3 and see how it feels
Post #537610 Sat Oct 07 2017 7:46am
It can't be 10 inches wider. It's not possible!
Post #537618 Sat Oct 07 2017 9:59am
nebc100
I think that the difference is actually because some measurements are including mirrors, and some without.
Post #537619 Sat Oct 07 2017 10:06am
murphy
Yes nebc100, that is probably the reason
Post #537620 Sat Oct 07 2017 10:14am
garrycol
Australia
The difference in width is minimal - inside width is basically the same. The RRS is shorter because the wheelbase is shorter. The drivers sear sits basically the same in both cars - differences are in adjustments available in different trim levels. My seat is adjustable up and down as are some D3 seats. Driving position is the same but feels different because of the upright nature of the D3 dash. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #537622 Sat Oct 07 2017 11:02am
