Home > Maintenance & Modifications > Poly bushes fitted and this happens :O
adameverett
Had an MOT done 2 weeks ago failed on front bushes Big Cry , last bushes only lasted 18 months :O elected to go for poly bush. (last set also fitted by my local Indy . Anyhow 2 weeks after having car back I take a look underneath Shocked
The rubber appear sliced by the arm? front offside
And a picture of the front near side.
Now the near side looks absolute fine and appears to have lots of room in the bush housing. It looks like the bushing has been sliced/pinched by the arm at some point. I lowered and raised the suspension and just cannot see how such a large slice of rubber has been knifed through. The rotation of the arm is only small compared the the slice of rubber that is hanging of the bush.
Something else just does not look right, if you look at the spaces on the good near side the rear bushing has a silver spacer and then the blue poly. If you look at the OSF bush there appears to be a blue then a black then silver spacer then the outer bush.
Then look again at the good NS bush front there is a blue then silver then blue bush, compare that to the front bush of the offside and it appears there is just a silver then blue bush. Confused
I am not an expert here but the shims are not consistent in use from NS to OS. I am feeling really Evil or Very Mad about this, its not a cheap job and this looks botched?
What do you guys think?
Post #536793 Sat Sep 30 2017 7:31pm
adameverett
Close up of Off side side shims
compared to near side Confused
Post #536795 Sat Sep 30 2017 7:40pm
GodivaNige
It looks as though the bushes have been rotating/spinning in the arm, have PMd you Adam
Post #536797 Sat Sep 30 2017 8:11pm
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
I have poly bushes fitted, the only ones listed were orange, are you sure they are poly bush?
Post #536889 Sun Oct 01 2017 10:42pm
Thought they did genuine Poly-Bushes in different colours for different applications i.e. Orange "Dynamic", Blue "Performance"
Etc. related to hardness or something like that, could well be wrong though.
With regards to the cut bush is it possible the did it when fitting the wishbone back onto the vehicle, if it was a bit tight to go in and they gave it a clout with a hammer it cut the bush on the sharp edge of the mounting, only a thought.
Post #536894 Mon Oct 02 2017 3:46am
adameverett
Did some googling, these are not Polybush (the trade name) but a polyurethane bush. A bit naughty to say they are Polybush, these look like Powerflex brand. Neutral
Could well be these https://www.powerflex.co.uk/road-series/pr...11260.html
http://www.powerflex.co.uk/i/product_images/3-32-402FI.pdf
The question is what the heck is that black band you can see on the failed side? Looking at the fitting instructions I cannot understand what that is.
Post #536907 Mon Oct 02 2017 8:35am
geoffsnook
A lot of people prefer these bushes as they are a little more compliant than the polybush which is harder but i would take that back to the indi and ask him to sort it out as it looks like it is not sat in there correctly Thumbs Up
Post #536913 Mon Oct 02 2017 9:35am
