![]() | Home > Technical > Rear demister. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Anyone know how much a rear screen is to replace? My rear demister doesn`t work. It`s been to an auto electrician and he said there`s power to the screen so the screen itself must be at fault |
Check the connections and then check your policy |
I assume that`s a spoiler off job? Steve. |
Yep |
**** that then |
OP's problem is very likely to be the corroded connector issue. Don't forget though that the battery conserving behaviour of the car includes selectively inhibiting high current consuming devices including the screen heaters. Accordingly on a cold day with a partially discharged battery it is common for the screen heaters to fail to work until the engine has been running for a few minutes.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5100 ![]() ![]() ![]() |
To remove spoiler its 2 torx bolts (which can be a little seized) and 3 10mm plastic buts
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9095 ![]() ![]() ![]() |
I wonder if the auto electrician actually took the connector apart to check for supply to the screen. How would he have checked otherwise?
mattdonut Member Since: 04 Sep 2017 Location: midlands Posts: 11 ![]() ![]() |
I did mine today really easy fix
Was it much ball ache taking the spolier off? I`d probably have to do it on my own. Steve. |
No mate it’s quite easy
Put a big towel on the roof as you'll have to lay the spoiler on it. When you refit the spoiler, be careful not to nip the rear washer supply pipe in between spoiler and roof as I once did! You won't realise until trying to wash the rear screen. 2008 MY Java Black TDV8 HSE
