![]() | Home > Technical > Removing a rear HST bumper |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I don`t know for sure but if they are the same, this may be of help.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5094 ![]() ![]() ![]() |
Exactly same as HSE etc. it's just the HST has a couple of extensions on the rear lower edge of the bumper due to it being slightly deeper, still easy enough just a few extra self tappers if I remember correctly.
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
Thanks guys,
Yes, completely forgot the HST bumper has a extra strengthening panel along the top edge which is retained by the push in retainers, the bumper is then clipped into the additional panel, you do not need to remove the strengthening panel to remove the bumper itself just unclip it, but it should have either a plastic or the stainless steel optional tread plate. The plastic one is clipped in the stainless one is held in place with double sided 3M tape.
