![]() | Home > Maintenance & Modifications > 21” wheels on 2011 sport |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Just replaced my 20” wheels and fitted a set of 2016 genuine 21” alloys on my 2011 sport
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
That depends on what tyre size is on. You can use a calculator like this - http://www.willtheyfit.com/ which will tell you the rolling circumference, and that is what dictates whether the speedo will be the same or not.
Thanks for that insiorc |
Tyrefitter the original tyres are 275/40/r20
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5110 ![]() ![]() ![]() |
I have been running the 21" wheels for nearly three years and difference in speedo reading is negligible, at 30mph according to GPS it is less than 1 mph, If anything it is more accurate than it was from factory as Andy said. The wheel/Tyre size is in the CCF but it will not allow it to be changed for what ever reason. I believe Patrick at Gap was working on it to enable it to be changed, but not sure if he has done it yet.
Cheers Col |
